Aeronutz Billion Dollar Brain
PC issues.
The following notes are a reminder to myself, you are welcome to learn from these but I cannot answer any questions – I am not a computer technician. If you bugger up your PC don’t blame me! But then again if it is not working anyway you have nothing to loose?
Despite having the latest Norton AntiVirus we have been having problems with email and Norton itself.
For example, the PC could not down load five emails, on three occasions, over two days. It either froze up or the connection to the server was lost
To resolve these mysterious problems a new hard drive was acquired so it can run as a separate replacement to the original. All the software for it would be loaded up from original discs so there should not be any errors or viruses etc.
Installation of the new drive and its formatting was easy, just follow the instructions. Loading up Windows 98 SE was no problem despite a warning that the system was already using an operating system – presumed to be the new hard drives own system??
But - The new drive does not now have the driver for the modem. The modem was investigated and it’s make and type found. The manufactures web site with drivers was found and a generic driver down loaded.
The Windows on the new hard drive said it could not find the existing modem and gives a list of ports available as COM 1 and COM 2. The modem is in COM 3. The BIOS software used when booting up the PC says the modem is indeed in COM 3 which is the card slot next to the screen driver card.
So we cant use the original modem because we don’t have the exact driver.
Note ! It now seems that Windows only says the Modem is in Com3 when the correct driver is installed
By definition the old hard drive must have the modem driver on it somewhere but this could not be found. In looking for the modem’s driver files a file (lmouse.drv) seems to have been lost but the mouse works ok? Also the original modem no longer works and the existing problems continue.
So a new modem was purchased, now we have the correct driver for it. After much confusion it turns out that this new modem is a Fax modem, which was not stated on the packaging! A test showed it did seem to call up a fax number Ok but not a phone line number! This new modem was very cheap so this was not too much of a problem.
A second new modem was purchased which specifically says it is for Fax, Data and voice. It’s suitable for Win 98 SE too.
This has been fitted and after a brief struggle its driver is loaded and the modem is now working. Windows now says the Modem is in Com3.
On dialling out, the second new modem can’t connect to the server ……. No reason given.
The troubleshoot guide for the modem suggests using the Microsoft HyperTerminal software to manually phone out via the new modem – to check the modem is working OK. This HyperTerminal is on the Windows 98 SE disc and has to be loaded specially. It is run via Accessories, Communications. It turns out that the modem can connect to the server if you do so manually, through the hyper terminal. But it does not want to connect to the server through the normal Windows dial up software.
So obviously the problem is with the Windows dial out software – sure enough it was.
Although the dial up details say use the dialling area code the system did not do so. This was corrected by adding the area code to the server’s local phone number! SO now there is a local area code in the local phone number and also in the box marked Aero Code.
There is some suspicion that Windows thinks it is in the US, despite being told its is in the uk. This is because the keyboard and spell check both came up as US after Windows was re installed?
Maybe Windows is confused about using it’s area code as a result?
So now we can dial out and get an update for the browser which is required because Anti Virus needs a more recent version than supplied on the Windows 98 SE disc, this new version of Internet Explorer was about 13 Mb so it look along while to down load and crash the PC while it was updating the files too.
Norton Security was installed and recent updates loaded up, one at a time to avoid loosing too much if the system freezes up.
Now the new hard drive is basically working Ok but the browser down loads web pages but the PC screen is displaying them as crude low resolution images.
Presumably this low quality image problem is due to the driver for the screen, I think this is part of the motherboard system so it might be possible to copy the files from the original hard drive to the new hard drive.
I have not tried using the speakers yet, maybe the driver is missing for those too.
The mouse works OK !
I will not try fixing the PC’s monitor problems until after the next news letter is finished, which is being done on the original hard drive.
Sometimes Anti Virus says it is not working, there can be several reasons for this and does not necessarily mean it is no actually working. One report said that the system had not done a recent scan check and another was because the files where not the latest updates.
So to summarise up to date.
  1. Hard drives are not too expensive so it might be a good ideal to buy one and get it working as a standby in case your current HD has problems – be self reliant rather than rely on the PC industry.
  2. If you are not currently having any problems it might be a good idea to copy the entire drive, including all driver software onto a disc or a new hard drive. Maybe install the new drive as a second hard drive to copy the original drivers data over ? If you system has a problem with it I assume you would just copy  the problem too?
If you do have a problem  and decide to delete and re install everything on your hard drive to resolve problems make sure you have the software/boot up discs for Windows and the hard drive itself. These should be on A drive floppy discs while the main software is probably on a CD disc.
  1. Find the correct drivers for your modem and PC monitor, maybe look on the original hard drive or down load from the manufactures web site?
  2. If you buy a new complete PC try and get a disc with the correct drivers on it. How do you know they are the correct ones?
  3. Load up the latest version of your browser before you load up Anti Virus. Load Norton updates one at a time and re boot so you don’t have to start again if the system “freezes up”
  4. Sometimes the server will stop you logging in because you have been on the system too much – this might cause the error message “cannot connect” which is not literally true.
  5. Even now the dial out software occasionally says it can’t find the modem, just try again or re boot last time I moved the modem to a different card slot and it re loaded the driver and now its ok.
